Notebook
Geändert 19.11.2010
lappi
Satellite Pro A120
Satellite Pro A120
| Codename | Yonah |
| Revision | C0 |
| Technologie | 65 nm |
| Taktrate | 1664 |
| Frontside Bus | 663 |
| L1 Cache | 128 |
| L2 Cache | 2048 |
| Northbridge | Intel i945GM Revision 03 |
| Southbridge | Intel 82801GHM (ICH7-M/U) Revision 03 |
| BIOS | Version 1.40 |
| Interne Anschlüsse | 1 PCMCIA |
| Größe | 1024 |
| Typ | DDR2 (PC2-5300) |
| Timing | 5-5-5-15-20 at 333.3 MHz, at 1.8 volts (CL-RCD-RP-RAS-RC) |
| Takt | 333 |
| Größe | 1024 |
| Typ | DDR2 (PC2-4300) |
| Timing | 5-4-4-12-16 at 266.7 MHz, at 1.8 volts (CL-RCD-RP-RAS-RC) |
| Takt | 266 |
| Chipset | Intel(R) GMA 950 |
| RAM | 256 |
| Treiber | 8.15.10.1825 |
| Typ | Festplatte (intern) |
| Details | Cache: 8192 KB |
| Kapazität | 120 |
| Interface | Serial ATA |
| Temperatur | 31.00 |
| Größe | 0" (0 cm x 0 cm) |
| Auflösung | 1280 x 800 @ 59Hz |
| CPU | 4.1 |
| RAM | 4.7 |
| Grafik | 3.1 |
| Grafik Spiele | 3.1 |
| HDD | 4.6 |
