Desktop
Geändert 19.05.2011
Sascha-Home
OptiPlex GX280
OptiPlex GX280
| Hersteller | Intel |
| Codename | Prescott |
| Revision | E0 |
| Technologie | 90 nm |
| Taktrate | 2793 |
| Frontside Bus | 798 |
| L1 Cache | 16 |
| L2 Cache | 1024 |
| Northbridge | Intel i915P/i915G Revision B1 |
| Southbridge | Intel 82801FB (ICH6) Revision B1 |
| BIOS | A04 |
| Interne Anschlüsse | 5 PCI |
| Größe | 1024 |
| Typ | DDR2 (PC2-5300) |
| Timing | 5-5-5-15-20 at 333.3 MHz, at 1.8 volts (CL-RCD-RP-RAS-RC) |
| Takt | 333 |
| Größe | 256 |
| Typ | DDR2 (PC2-4300) |
| Timing | 5-4-4-12-16 at 266.7 MHz, at 1.8 volts (CL-RCD-RP-RAS-RC) |
| Takt | 266 |
| Größe | 256 |
| Takt | 266 |
| Chipset | GeForce 8600 GS |
| RAM | 512 |
| Treiber | 6.14.12.7061 |
| Typ | Festplatte (intern) |
| Details | Cache: 29999 KB |
| Kapazität | 1000 |
| Interface | Serial ATA |
| Temperatur | 32.00 |
| Größe | 14.9" (30 cm x 23 cm) |
| Auflösung | 1024 x 768 @ 60Hz |
